DLWhite
Mar 17, 2018Aspirant
Lost connection to AC791L Display and Admin Page
Hello, My AC791L Verizon Jetpack stays plugged in 99% of the time. Lately I've noticed that, after a period of time, the display won't illuminate and the admin page becomes inaccessable even though ...
JasonN
Mar 22, 2018NETGEAR Employee Retired
Hi DLWhite,
I had a question. If your device is plugged in 99% of the time, do you leave the battery in also? If so, then I can see the device might be over heating if your battery is left charged while it is up for 24-48 hours.
Please let me know. :]
- Jason N
- DLWhiteMar 22, 2018Aspirant
Hi, Jason.
Yes, the battery is in the jetpack while it is plugged in; I don't think the AC791L will function without the battery, will it?
Anyway, when I remember to unplug it overnight, I retain access to the admin page and the display lights consistently. So my problem may very well be that the battery is overheating.
Thanks for your reply!
Delia
- JasonNMar 22, 2018NETGEAR Employee Retired
Hi DLWhite,
It's not good to leave the battery fully charged on the charger. I earlier models work with the battery out but you just have to leave it plugged into the charger.
Can you try this setup and see if it works for you?
- Jason N
Hi, Jason.
The AC791L does not work without the battery. :( I guess I just need to unplug it for a little while each day. Thanks again for your help.
D
