hhhhhhhhk
Mar 09, 2021Follower
Lte modem LB1120 amber light
My modem was working fine until last night, it now shows an amber bar over the power but it shows green bars next to it. I logged onto the page and tried to update it but it keeps saying “there was a problem try again later” any tips?? I also tried switching to a dif SIM card with a dif provider but that didn’t work either (I’m using AT&T I tried T mobile)
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi hhhhhhhhk
Welcome to NETGEAR Community!
If the Power LED bar is amber and individual signal strength bar lights solid green while other are off, we suggest to check the link below for the list of error conditions and its possible solution
[page 85 - 86] https://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf
Blanca
Community Team
