Sixtsixmike
Mar 27, 2018Aspirant
M1 antenna setup
Hello all, Just ordered 2 Wilson 10dbi yagi's and cables and patch cords, etc. My question is how do you have yours mounted? Stacked, side by side, or + 45 -45 In in a rural area in east T.N. and ...
nhantenna
Mar 28, 2018Apprentice
"Stacked, side by side, or + 45 -45"
I've been looking for the answer since last year. I am rural as well and have a single yagi. The answer will ultimately depend on how the Nighthawk works internally and how your local AT&T cell tower is configured.
MIMO vs CA. MIMO helps in city environments where radio is bouncing off of everything (buildings, buses, etc.) In a rural setting we do not have these city multipath problems. That said *if* the Nighthawk supports MIMO with a second external antenna, that second antenna may do nothing for you. I would recommend you start with one external antenna to see what you get before adding a second antenna.
CA is another thing all together. The ability for multiple radios to work independent of one another. *If* the Nighthawk supports CA with two external antennas the second antenna may do alot for your performance.
Netgear does not disclose any information about how the Nighthawk MIMO or CA works. From previous forum posts this MIMO and CA information is not exposed in Nighthawk web console so even if something is happening under the covers we will not know about it. The only thing we'll know for certain is speedtest results! My yagi is mounted with the elements vertical. I have never tried it in any other orientation. I get 50Mbit download peak speeds.
My best advice for you:
1) Get one antenna working the best you can to baseline performance.
2) After adding a second antenna, try both vertical and +/- 45 setups to see what works. I've read about +/- 45 but have NEVER seen actual speedtest results in the United States on AT&T using the +/- 45 setup.
3) Keep the antennas at least an antenna width apart. If your yagi is six inches wide, mount the two yagis at least six inches apart. Stacked or side by side should not matter at all.
