Rob517
Nov 03, 2021Follower
M1 Can't change WiFi Channels
Hi All,
I just setup a new M1 and the interface will allow me to select a new WiFi channel (2.4Ghz) but I cannot "APPLY" it. The button turns red and will not me click it. It will only allow it to remain on the "AUTO" setting in both 2.4 and 5Ghz. Am I missing something here?
Also, is there a way to diable the automatic firmware updates?
Thanks for the help.
- ymmTutor
Same here. I'm not able to apply changes to the channel selection. I was told there is no way to disable automatic firmware updates.
- ymmTutor
Figured it out: To change change channel both main (2.4G) and secondary (5G) need to changed from auto. Worked from the iOS App but not from either Chrome or Edge browsers....
