Seandy's avatar
Seandy
M1 Nighthawk and 3G
Hi, can I "tell" my Nighthawk M1 to use the 3G network not the 4G.
I occasionally use mine in an area where 4G cuts in and out: I used to "tell" my old Sierra aircard to use 3G only.
Thanks
  • hi Betreff , yes you can go to: settings > advanced settings > cellular > band region > WDCMA all : this will lock you to 3G frequencies
