louis1976
May 08, 2023Aspirant
M1 Nighthawk data limit
Last week I got an unwanted bill for my data usage.
My daughter was streaming movies while connected with the M1100EU nighthawk.
There is a data alert feature, but I can't find the data cap feature.
Is there one or is there another way to cap the data usage?
thx.
Louis
I took a look at mine and didn't see a way in the settings on the device or the app. Or if there is, I couldn't find it.
Might be worth checking through your account to see if your ISP has a hard limit cap they can set.
- louis1976Aspirant
Unfortunately the latter is not possible.
I could change ISP, but you would think such a feature is a must-have.Thanks for your reply!
