dapatter
Jan 11, 2020Aspirant
M2 passthrough to Nighthawk D7000v2
Hi I have an M2 setup in IP Passthrough, dhcp disabled etc. I can plug pc in on ethernet and connect to the internet fine. When I plug it into the WAN port of the Nighthawk D7000v2, it gets the internet WAN settings fine, but I am unable to access the WAN IP of the M2 or devices behind the D7000v2 are unable to get internet access.
I am stumped? It should work and the WAN IP etc is all being picked up, but just cant access the interent. is there a specific MAC address I need to use / restriction?
- dapatterAspirant
Yes the devices behind the router are reachable and yes the devices have been rebooted several times. I sorted out the issue, looks lile one of the SONOS speakers when plugged in was bringing down the ethernet port on the M2.
