yuresh
Jan 22, 2024Aspirant
M4250 vs M4300
What is the main difference between these two series? We use it primarily for NDI, DANTE, and Streaming. The M4250 is perfect for this and I see the M4300 is part of the AV line as well. I assume it uses the same Engage Controller and has all the settings like NDI, DANTE, etc. to make configuring easy and fast. I am asking because an AV facility is selling them, and I am hoping I can add and integrate them into our existing M4250 switches easily.
1 Reply
- schumakuGuru - Experienced UserCarefully compare the Data Sheet | M4300 series, predominantly 10 Gb ports and the matching switch fabric bandwidth capacity; modular with 40 Gb ports, with the Data Sheet | M4250 Series, predominantly 1 Gb ports plus some 10 Gb uplink ports and the matching switch fabric bandwidth capacity, and several PoE+/PoE++ versions for all power requirements on copper ports of course .. there are all answers already. Before you ask, compare the Data Sheet | M4350 Series which is covering models with predominantly 1 Gb ports, models with predominantly 10 Gb ports, and models with predominantly 25 Gb ports, always with the the matching switch fabric bandwidth capacity, and several PoE+/PoE++ versions for all power requirements on coper ports of course.
