Havhingstor
Aug 10, 2023Aspirant
M5 doesn't connect to Vodafone
I've got a Nighthawk M5 (Firmware NTGX55_12.04.17.00) and want to connect it to a Vodafone CallYa Prepaid Plan. The SIM Card does work with multiple other devices (iOS and Android) and did also work ...
CH1985
I also have a nighthawk mr5200 HW1.3 SW
MR5200-100EUS_NTGX55_12.04.17.00_Generic_04.07
I have Problems to connect to Vodafone when only LTE B20 is available, other LTE Bands work without problems. Settings are always the same. I tried also a factory reset.
JohnPeng should i send you the log files and the config?
regards Christoph
