Havhingstor
Aug 10, 2023Aspirant
M5 doesn't connect to Vodafone
I've got a Nighthawk M5 (Firmware NTGX55_12.04.17.00) and want to connect it to a Vodafone CallYa Prepaid Plan. The SIM Card does work with multiple other devices (iOS and Android) and did also work ...
Havhingstor
Aug 21, 2023Aspirant
It currently seems to connect sometimes, without me changing any settings. This appears to be caused by the antenna, maybe it's not functioning correctly, since an Android Tablet is able to connect reliably and I'm assuming the antenna in this tablet should generally be worse than the antenna in the Nighthawk. We're going to contact the refurbished-seller we bought the device from.
The point is, I don't think this is an issue that can be fixed by changing a setting.
