Fhx_30's avatar
Fhx_30
Follower
May 15, 2022
M5 mr5100 Only works on external antenna
M5 mr5100 Only works on external antenna If it is disconnected from the external antenna, it does not work and a message appears mobile broadband disconnected It was working before and there were no problems, but after connecting and disconnecting the external antenna, this problem appeared
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Could you please advise which external antenna was used with the device?
    Thanks
