jeffbh's avatar
jeffbh
M5 (MR5200) - How to enable IP Passthrough?
Model is a Nighthawk M5 5G Mobile Router MR5200 (Unlocked).  I am trying to use it as (only) a modem connected to one of the WAN ports of a separate router.  I see people saying that they're using the device in this configuration "with IP Passthrough".  How do I enable that?
Maybe I'm just missing it, but I cannot find IP Passthrough as an option in the admin web interface. I can only find VPN Passthrough.
Thanks for any help.
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please advise your device SKU name and FW version on your device. Is it MR5200-100EUS or MR5200-100NAS?
    Thanks
    • jeffbh's avatar
      jeffbh
      Here’s what Device Info shows. Is this enough info?
      NETGEAR
      Device Information
      PRI Version: 02.02
      Web App Version: MR5200-
      100EUS 04.02.196.00
      Modem Version: MPSS.HI.2.0.c3.5-00010-
      SDX55 CPEALL PACK-1.403198.3
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        Please follow the steps below to enable IP Passthrough.
        "You can log in to WebUI and go to Seetings -> Setup -> Mobile Router Setup -> Under IP Passthrough, select ON Disable WiFi on the mobile router.
        You can give it a try and le me know if you have any issues. The WAN stability issue is also related carrier network. You may not see the issue for sure.
        Thanks"
