ChePepito
Aug 07, 2025Aspirant
M5 Nighthawk MR5200 Problem Acces Intern
Hello, I am reaching out for assistance with my Netgear Nighthawk M5 router. I have a 5G Surf Unlimited subscription with Salt (Switzerland), and the SIM card works perfectly when used in my mobi...
ChePepito
Hi,
Thanks for you answer schumaku
Indeed it's written SKU: MR5200-100EUS --> what does it means ?
this is the .json file in attached (It's kind of logs ? i was looking for that but i don't understand that much... anw thanks) .
Meanwhile, i succeed 1 time to open a web page ! (and i put APN to: "chili", ive found online another APN for salt they said) but after it didn't work anymore...
I looked at the statue of signal, it seems that all the time it "changes" frequency (pass from band: LTE B1 to B3), and when it is on B3 it seems-sometimes- it works. Can it be related to the stability of the frequency that doesn't work ? and my M5 try always to change dynamically ? (and i can't fix it's reception frequency).
Idk, i try everything now... thanks for your helped man.
- ChePepitoAug 07, 2025Aspirant
Sorry this is the file
