pprindeville
Feb 01, 2026Guide
M6 and IP-passthrough with routable static IP
I have an M6 Pro (MR6550) and a T-Mobile business internet account, and I'm unable to use the M6 in passthrough mode. The M6 (the hotspot) does some pretty inexplicable things. Like ARP my firew...
pprindeville
Feb 01, 2026Guide
Because for some mysterious reason, .txt attachments aren't allowed:
root@OpenWrt2:~# iperf3 -c 84.17.41.11 -p 5201 -t 60 -Z Connecting to host 84.17.41.11, port 5201 [ 5] local 162.191.234.12 port 40326 connected to 84.17.41.11 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 2.12 MBytes 17.8 Mbits/sec 0 729 KBytes [ 5] 1.00-2.00 sec 7.38 MBytes 61.8 Mbits/sec 0 1.17 MBytes [ 5] 2.00-3.00 sec 8.12 MBytes 68.2 Mbits/sec 0 1.54 MBytes [ 5] 3.00-4.00 sec 6.88 MBytes 57.7 Mbits/sec 0 1.91 MBytes [ 5] 4.00-5.00 sec 3.12 MBytes 26.2 Mbits/sec 390 592 KBytes [ 5] 5.00-6.00 sec 1.25 MBytes 10.5 Mbits/sec 671 2.71 KBytes [ 5] 6.00-7.00 sec 1.75 MBytes 14.7 Mbits/sec 92 1.08 MBytes [ 5] 7.00-8.00 sec 8.12 MBytes 68.1 Mbits/sec 0 1.45 MBytes [ 5] 8.00-9.00 sec 6.88 MBytes 57.7 Mbits/sec 0 1.82 MBytes [ 5] 9.00-10.00 sec 2.62 MBytes 22.0 Mbits/sec 1 1.36 KBytes [ 5] 10.00-11.00 sec 0.00 Bytes 0.00 bits/sec 32 24.4 KBytes [ 5] 11.00-12.00 sec 2.75 MBytes 23.1 Mbits/sec 1453 1.39 MBytes [ 5] 12.00-13.00 sec 6.75 MBytes 56.6 Mbits/sec 0 1.76 MBytes [ 5] 13.00-14.00 sec 4.00 MBytes 33.5 Mbits/sec 3 1.75 MBytes [ 5] 14.00-15.00 sec 0.00 Bytes 0.00 bits/sec 6 1.70 MBytes [ 5] 15.00-16.00 sec 0.00 Bytes 0.00 bits/sec 6 1.69 MBytes [ 5] 16.00-17.00 sec 0.00 Bytes 0.00 bits/sec 6 1.69 MBytes [ 5] 17.00-18.00 sec 0.00 Bytes 0.00 bits/sec 7 1.67 MBytes [ 5] 18.00-19.00 sec 0.00 Bytes 0.00 bits/sec 7 1.66 MBytes [ 5] 19.00-20.00 sec 0.00 Bytes 0.00 bits/sec 6 1.65 MBytes [ 5] 20.00-21.00 sec 0.00 Bytes 0.00 bits/sec 6 1.64 MBytes [ 5] 21.00-22.00 sec 2.12 MBytes 17.8 Mbits/sec 7 1.56 MBytes [ 5] 22.00-23.00 sec 2.12 MBytes 17.8 Mbits/sec 7 1.40 MBytes [ 5] 23.00-24.00 sec 0.00 Bytes 0.00 bits/sec 5 1.22 MBytes [ 5] 24.00-25.00 sec 0.00 Bytes 0.00 bits/sec 6 1.18 MBytes [ 5] 25.00-26.00 sec 0.00 Bytes 0.00 bits/sec 4 1.17 MBytes [ 5] 26.00-27.00 sec 0.00 Bytes 0.00 bits/sec 127 86.8 KBytes [ 5] 27.00-28.00 sec 6.12 MBytes 51.4 Mbits/sec 356 1.26 MBytes [ 5] 28.00-29.00 sec 8.38 MBytes 70.3 Mbits/sec 0 1.64 MBytes [ 5] 29.00-30.00 sec 5.62 MBytes 47.2 Mbits/sec 1 1.88 MBytes [ 5] 30.00-31.00 sec 0.00 Bytes 0.00 bits/sec 6 1.60 MBytes [ 5] 31.00-32.00 sec 1.62 MBytes 13.6 Mbits/sec 6 1.58 MBytes [ 5] 32.00-33.00 sec 0.00 Bytes 0.00 bits/sec 7 1.53 MBytes [ 5] 33.00-34.00 sec 0.00 Bytes 0.00 bits/sec 4 1.36 KBytes [ 5] 34.00-35.00 sec 2.50 MBytes 21.0 Mbits/sec 325 1.42 MBytes [ 5] 35.00-36.00 sec 0.00 Bytes 0.00 bits/sec 7 1.19 MBytes [ 5] 36.00-37.00 sec 0.00 Bytes 0.00 bits/sec 6 1.16 MBytes [ 5] 37.00-38.00 sec 0.00 Bytes 0.00 bits/sec 5 2.71 KBytes [ 5] 38.00-39.00 sec 0.00 Bytes 0.00 bits/sec 252 174 KBytes [ 5] 39.00-40.00 sec 3.50 MBytes 29.4 Mbits/sec 199 950 KBytes [ 5] 40.00-41.00 sec 0.00 Bytes 0.00 bits/sec 7 893 KBytes [ 5] 41.00-42.00 sec 0.00 Bytes 0.00 bits/sec 3 884 KBytes [ 5] 42.00-43.00 sec 3.12 MBytes 26.2 Mbits/sec 23 907 KBytes [ 5] 43.00-44.00 sec 7.00 MBytes 58.7 Mbits/sec 0 1.22 MBytes [ 5] 44.00-45.00 sec 7.12 MBytes 59.8 Mbits/sec 0 1.58 MBytes [ 5] 45.00-46.00 sec 6.75 MBytes 56.6 Mbits/sec 0 1.95 MBytes [ 5] 46.00-47.00 sec 0.00 Bytes 0.00 bits/sec 6 1.68 MBytes [ 5] 47.00-48.00 sec 0.00 Bytes 0.00 bits/sec 6 1.67 MBytes [ 5] 48.00-49.00 sec 0.00 Bytes 0.00 bits/sec 6 1.66 MBytes [ 5] 49.00-50.00 sec 0.00 Bytes 0.00 bits/sec 6 1.65 MBytes [ 5] 50.00-51.00 sec 0.00 Bytes 0.00 bits/sec 7 1.64 MBytes [ 5] 51.00-52.00 sec 0.00 Bytes 0.00 bits/sec 6 1.63 MBytes [ 5] 52.00-53.00 sec 0.00 Bytes 0.00 bits/sec 6 1.62 MBytes [ 5] 53.00-54.00 sec 1.62 MBytes 13.6 Mbits/sec 8 1.46 MBytes [ 5] 54.00-55.00 sec 0.00 Bytes 0.00 bits/sec 6 1.43 MBytes [ 5] 55.00-56.00 sec 0.00 Bytes 0.00 bits/sec 16 17.6 KBytes [ 5] 56.00-57.00 sec 2.88 MBytes 24.1 Mbits/sec 10 1.30 MBytes [ 5] 57.00-58.00 sec 0.00 Bytes 0.00 bits/sec 7 1.16 MBytes [ 5] 58.00-59.00 sec 0.00 Bytes 0.00 bits/sec 17 10.8 KBytes [ 5] 59.00-60.00 sec 3.50 MBytes 29.3 Mbits/sec 468 1.09 MBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-60.00 sec 126 MBytes 17.6 Mbits/sec 4624 sender [ 5] 0.00-60.14 sec 123 MBytes 17.1 Mbits/sec receiver iperf Done. root@OpenWrt2:~#Note the intervals were zero packets got through: 15, 19-25, 28-31, ...
I've even been told by tech support that my SLA didn't have enough bandwidth and that's why a one packet-per-second test was failing (the ping below).
# ping -c 100 24.116.100.90 PING 24.116.100.90 (24.116.100.90): 56 data bytes 64 bytes from 24.116.100.90: seq=0 ttl=54 time=90.591 ms 64 bytes from 24.116.100.90: seq=1 ttl=54 time=52.553 ms 64 bytes from 24.116.100.90: seq=2 ttl=54 time=164.566 ms 64 bytes from 24.116.100.90: seq=3 ttl=54 time=124.372 ms 64 bytes from 24.116.100.90: seq=4 ttl=54 time=60.166 ms 64 bytes from 24.116.100.90: seq=5 ttl=54 time=50.402 ms 64 bytes from 24.116.100.90: seq=6 ttl=54 time=162.617 ms 64 bytes from 24.116.100.90: seq=7 ttl=54 time=57.555 ms 64 bytes from 24.116.100.90: seq=8 ttl=54 time=59.098 ms 64 bytes from 24.116.100.90: seq=25 ttl=54 time=639.718 ms <======= 64 bytes from 24.116.100.90: seq=26 ttl=54 time=60.880 ms 64 bytes from 24.116.100.90: seq=27 ttl=54 time=67.038 ms 64 bytes from 24.116.100.90: seq=28 ttl=54 time=56.424 ms 64 bytes from 24.116.100.90: seq=29 ttl=54 time=63.629 ms 64 bytes from 24.116.100.90: seq=30 ttl=54 time=58.553 ms 64 bytes from 24.116.100.90: seq=31 ttl=54 time=110.747 ms 64 bytes from 24.116.100.90: seq=32 ttl=54 time=56.388 ms 64 bytes from 24.116.100.90: seq=33 ttl=54 time=70.281 ms 64 bytes from 24.116.100.90: seq=52 ttl=54 time=66.309 ms <======= 64 bytes from 24.116.100.90: seq=53 ttl=54 time=181.092 ms 64 bytes from 24.116.100.90: seq=54 ttl=54 time=55.216 ms 64 bytes from 24.116.100.90: seq=55 ttl=54 time=55.123 ms 64 bytes from 24.116.100.90: seq=56 ttl=54 time=53.488 ms 64 bytes from 24.116.100.90: seq=57 ttl=54 time=71.008 ms 64 bytes from 24.116.100.90: seq=58 ttl=54 time=54.779 ms 64 bytes from 24.116.100.90: seq=59 ttl=54 time=64.302 ms 64 bytes from 24.116.100.90: seq=74 ttl=54 time=2816.721 ms <======= 64 bytes from 24.116.100.90: seq=75 ttl=54 time=1816.697 ms 64 bytes from 24.116.100.90: seq=76 ttl=54 time=816.189 ms 64 bytes from 24.116.100.90: seq=77 ttl=54 time=56.368 ms 64 bytes from 24.116.100.90: seq=78 ttl=54 time=58.980 ms 64 bytes from 24.116.100.90: seq=79 ttl=54 time=56.697 ms 64 bytes from 24.116.100.90: seq=80 ttl=54 time=52.612 ms 64 bytes from 24.116.100.90: seq=81 ttl=54 time=66.038 ms 64 bytes from 24.116.100.90: seq=82 ttl=54 time=76.089 ms 64 bytes from 24.116.100.90: seq=83 ttl=54 time=69.489 ms 64 bytes from 24.116.100.90: seq=84 ttl=54 time=205.059 ms <======= --- 24.116.100.90 ping statistics --- 100 packets transmitted, 37 packets received, 63% packet loss round-trip min/avg/max = 50.402/235.076/2816.721 msI've put arrows next to interruptions of packet flows (losses).
