W1lliam's avatar
W1lliam
Virtuoso
Jul 20, 2023
M6 MR6110-1TLAUS NR5G is not working here
JohnPeng I believe it is the same cause as MR6450-100EUS, NR5G is not working here in Taiwan. Upgraded over NTGX65_12.01.22.00 (dated 2023/5/15) same problem as previous FW. Telstra might not have interest to get this resolved, just hope that this can be fixed on next release, if any. It is not just a particular model has issue on NR5G, all the M6/M6Pro, which has needed NR5G bands supported here, that I tested are not working till recent update for MR6450-100EUS/MR6550-100PAS.
This product is a portable WiFi to Broadband device, even if some of SKU are designed for particular carrier(s), when people taking it for travel, sooner or later would run into similar issue. This never happened on M5 which gives high confidence but turns out M6/M6Pro is not the same.
  • Yes. This should be the same issue. But since it took time for Telstra TA on 12.01.22.00. We couldn't get the fix to the official Telstra TA'ed release. But will address this in the next MR for sure. The issue was fixed on 12.01.25.00. So any older release will not have the fix.
    Thanks
    John
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Thanks
    John
