BartMel's avatar
BartMel
Tutor
Feb 02, 2023
M6 Pro (MR6450) supported band combinations
Hi,
From the datasheet of the M6 Pro, it seems that B40 LTE and n78 NR is supported, but is the band combination B40/n78 supported for use in a 5G NSA network?
Also, are there any restrictions when using n78 for 5G SA network?
This would be for use in Germany (in case there are multiple FW versions)
Thanks
Bart
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi BartMel
    NETGEAR has several different SKUs of the Nighthawk M6 Mobile Router products and each product has a specific set of bands that is supports based on the region that it is purchased in.
    Kindly check this KB link: https://kb.netgear.com/000065402/
    Blanca
    Community Team
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      B40+n78 is supported on the SKU and also the device support SA mode for all NR bands.
      Thanks
      John
