DARK66SABER
Jun 17, 2023Tutor
M6 Pro stuck in a reboot cycle
So I have an M6 Pro through AT&T on a first net sim. My issue started recently after a firmware update. Prior to the update, I had no issues whatsoever. Now it seems the device is stuck in a reboot cy...
Fidgety
Jun 17, 2023Aspirant
I have a similar problem probably from the same update a few days ago. There is a tiny button under the cover to reset it but it didn’t work for me. It’s the size of a paper clip hole . I feel I might just have an over priced paper weight now.
DARK66SABER
Jun 18, 2023Tutor
I’ve tried everything that I can possibly think of from using the reset button multiple times, to running it with the battery in, running it with the battery out on AC power, trying to force a software update and nothing has seemed to work. I’ve seen other threads where people have the same sort of issues but there seems to be no solution. I have noticed that when I boot it without the SIM card inserted it boots right up and performs as it should, but it has no service connection due to the SIM card being out. I’m stumped and I don’t want to keep paying for something that I’m not getting any use out of.
