DARK66SABER
Jun 17, 2023Tutor
M6 Pro stuck in a reboot cycle
So I have an M6 Pro through AT&T on a first net sim. My issue started recently after a firmware update. Prior to the update, I had no issues whatsoever. Now it seems the device is stuck in a reboot cy...
Blanca_O
Jun 20, 2023NETGEAR Employee Retired
Hi, All,
Our engineering team is aware of the issue and is currently investigating and working on a fix. I will be sure to update the thread as soon as I can.
May I also request for the following information:
- Location (City, State)
- Are you using a FirstNet SIM? Have you tried another SIM?
- Device SKU (e.g. MR6500-100NAS)
- Firmware version
Blanca
Community Team
Fidgety
Jun 21, 2023Aspirant
