Autoben
Oct 29, 2025Aspirant
M6 PRO Wifi Signal Dropping Out
We have a M6 Pro Nighthawk modem which has been great & worked very well the past couple of years. The Nighthawk is connected directly to power with no battery fitted & has a couple of wifi camera...
Fortra
Oct 30, 2025Luminary
Ok, I understand, like you had mentioned above it could be due to the update that was installed. However, I was wondering if you try a few short mini test. By reducing the amount of wifi devices that is connected to it, for example 1 or 2 then after 20 or 30 minutes connect your other 3rd and 4th devices. What I'm looking out for is, that your M6 Pro router "processing chip" or other components inside, your router, since the update was installed, might be generating "heat instability" due to the amount of connected wifi devices connected to it, eg work load on the router. Basically your trying to narrow down, what is causing the problem of the wifi dropping off.
- AutobenNov 01, 2025Aspirant
Yeah we have tried only running one or two devices & it still has the same issue. Please note the same amount of devices have been running off this for the past couple of years (no change in demand), thanks.
