Autoben
Oct 29, 2025Aspirant
M6 PRO Wifi Signal Dropping Out
We have a M6 Pro Nighthawk modem which has been great & worked very well the past couple of years. The Nighthawk is connected directly to power with no battery fitted & has a couple of wifi camera...
Fortra
Oct 31, 2025Luminary
Hi Autoben,
Correction to my post above, your mobile version router will be internally different to mine. So your hardware circuitry will be of a different "chip/modem" and components etc. However, the diagram shown above, for example, in your case, you will have to use a different "firmware" update & "pri version"for your location for your device.
