Autoben
Oct 29, 2025Aspirant
M6 PRO Wifi Signal Dropping Out
We have a M6 Pro Nighthawk modem which has been great & worked very well the past couple of years. The Nighthawk is connected directly to power with no battery fitted & has a couple of wifi camera...
Fortra
Oct 31, 2025Luminary
Bare in mind that a lot of electronic devices these days will run only at 2.4Ghz speeds only. Of which could cause a lot of slower speed congestion channels overload Some newer modern devices will also work at higher 5.0Ghz speeds too providing better connectivity, with better HD quality.
- FortraNov 01, 2025Luminary
Please note, surfing on the internet via "mobile devices has it's limitations" general surfing on the internet isn't a problem. However, if you plan to do more via complex bandwidth eating electronic devices on a "WiFi only" connectivity on "2.4Ghz" limitation, good luck.
