Autoben
Oct 29, 2025Aspirant
M6 PRO Wifi Signal Dropping Out
We have a M6 Pro Nighthawk modem which has been great & worked very well the past couple of years. The Nighthawk is connected directly to power with no battery fitted & has a couple of wifi camera...
Fortra
Oct 31, 2025Luminary
Bare in mind that a lot of electronic devices these days will run only at 2.4Ghz speeds only. Of which could cause a lot of slower speed congestion channels overload Some newer modern devices will also work at higher 5.0Ghz speeds too providing better connectivity, with better HD quality.
Fortra
Nov 01, 2025Luminary
Please note, surfing on the internet via "mobile devices has it's limitations" general surfing on the internet isn't a problem. However, if you plan to do more via complex bandwidth eating electronic devices on a "WiFi only" connectivity on "2.4Ghz" limitation, good luck.
