Autoben
Oct 29, 2025Aspirant
M6 PRO Wifi Signal Dropping Out
We have a M6 Pro Nighthawk modem which has been great & worked very well the past couple of years. The Nighthawk is connected directly to power with no battery fitted & has a couple of wifi camera...
ross8888
Oct 31, 2025Aspirant
That sounds really frustrating. It does seem like the latest firmware might be the culprit, especially since others have reported similar issues. Try restarting or doing a factory reset to see if it helps, but if not, it’s probably best to reach out to Netgear support, they might need to release a fix for this update.
Autoben
Nov 01, 2025Aspirant
Yeah thanks, have factory reset multiple times & even swapped the modem over with a spare MR6500 modem we have & same result, signal drops out after a couple of hours (like standby mode). The only way we can get it working again is to disconnect power & turn on again.
Any ideas on the best way to contact NETGEAR Support in Australia?
