Autoben
Oct 29, 2025Aspirant
M6 PRO Wifi Signal Dropping Out
We have a M6 Pro Nighthawk modem which has been great & worked very well the past couple of years. The Nighthawk is connected directly to power with no battery fitted & has a couple of wifi camera...
Autoben
Nov 02, 2025Aspirant
Thanks, but there is no cable NBN line or Ethernet option at the property, hence why we are using a wireless mobile modem for wifi signal.
Fortra
Nov 02, 2025Luminary
May I remind you, in your initial post in this thread, you also mentioned that, You have a"Nighthawk M6 Pro" mobile device, In that you've been using it for sometime "A fewYears". I'm fully aware it has Wifi capability, & it has also a "Builtin Ethernet port" socket too!
A separate network Ethernet port switches, are not too expensive, and come in various form factor sizes, as in "Small portable one", or "rack mountable" expensive ones too.
Like I had mentioned before above, there are some limitations, to how one uses their own mobile router devices!
