Autoben
Oct 29, 2025Aspirant
M6 PRO Wifi Signal Dropping Out
We have a M6 Pro Nighthawk modem which has been great & worked very well the past couple of years. The Nighthawk is connected directly to power with no battery fitted & has a couple of wifi camera...
Autoben
Nov 01, 2025Aspirant
Yeah the wifi cameras are only running on 2.4Ghz, No general surfing of the internet or downloads on this modem (just used for cameras only).
No one has access to this modem & the only devices connected are the cameras.
Fortra
Nov 04, 2025Luminary
Basically, it's similar to using (Bluetooth earbuds or other make headphones) once you go out of range of your mobile phone, the sound quality drops off, or you just get cut off totally!
