Autoben
Oct 29, 2025Aspirant
M6 PRO Wifi Signal Dropping Out
We have a M6 Pro Nighthawk modem which has been great & worked very well the past couple of years. The Nighthawk is connected directly to power with no battery fitted & has a couple of wifi camera...
Autoben
Nov 02, 2025Aspirant
Thanks, but there is no cable NBN line or Ethernet option at the property, hence why we are using a wireless mobile modem for wifi signal.
Fortra
Nov 05, 2025Tutor
Autoben, wrote,
That doesn't matter!
There is a (Single Ethernet port socket) on your mobile router device already. All you'll have to do is ask someone with some technical experience to provide you with an ethernet cable.
You can get them in various lengths sizes, via online, or from an electronic shop on the high street near you.
- Pro's & Con's - It's dirt cheap Wi-Fi cctv cameras has no wiring connection. However, it has to be (working) within Wifi range of your router device, and free from interference e.g building insulation, or metal beams, or other electrical devices etc. One more thing to add, in your neighbourhood there might be other users on the same 2.4Ghz frequency as you. But on their own wifi setup, which might affect wifi performances to some degree, in your area.
