user-not-found
Jan 16, 2026Aspirant
M7 Pro (MR7400)... Bridge Mode/IP-Passthrough Only Works After Reboot?
As the topic says... If I reboot the router to which the M7 is attached via eth, then I have to reboot the M7 as well before bridge mode works. Has anyone else experienced this, or the contrary;...
rcpax
Jan 17, 2026Luminary
you should be able to reboot your router downstream from the M7 and it will pickup an IP after reboot. i have an M6 Pro and this is how it behaves. I imagine it's not going to be that different in the M7
- user-not-foundJan 19, 2026Aspirant
Hey... thanks for responding. You are correct, it works when you reboot the M7. It's always nice to get confirmation from someone else of "works that way for me too". My point is that it only works when you reboot the M7.
When the connection drops out or the IP address becomes invalid for any reason means someone has to physically walk to the M7 and reboot it. Given the M7's ability to connect external antennae means it has many use cases where the device is not simply right in front of you. Since everything usually works as soon as it's rebooted my point is that any device should be re-issuing a DHCP request whenever a re-connection is possible... and there's no technical reason why it can't, or shouldn't.
...or at least provide the ability to manually provoke the process to run and anyone with my use-cases can implement the rest themselves.
- rcpaxJan 19, 2026Luminary
this is a mobile device and is not meant for remote installation. it seems like you are talking about the instance when the device loses connection from the cell site and you're saying the only way to get connectivity is to reboot your device? I re-read your post, you did not describe it that way. i also have instances of that happening and I have made myself a DIY reboot device where it pings a stable IP like 8.8.8.8, and if for some reason it does not get a response, it re-cycles the power to my M6 Pro. There are commercial devices sold for this exact purpose, just google it. you can get something that would cycle the AC supply of the power brick connected to your M7.
I'm talking about IP connectivity failure where one can't even ping the internal IP address of the M7 (devices can still keep a local/private IP address even when IP passthrough is activated) which can't be related cellular connectivity because they're totally different eth interfaces internally within the M7. Even if it were cellular connectivity it's still not required to reboot a device to re-establish connectivity to the cell network.
I looked at packet captures just now to see if there's anything deeper I can see. In the specific instance of this packet capture, the M7 IPv4 stack has stopped responding to ARP requests even though it is still sending them. My local ARP cache is showing an expired ARP lease for the IPv4 gateway address and thus no packets can be sent to the IPv4 gateway. For completeness, IPv6 ND is still working and so I can ping the IPv6 (link-local) gateway. I would definitely class this as a bug.
- user-not-foundJan 20, 2026Aspirant
Just re-read your post also and realized you were talking about rebooting my own router... My router does make the DHCP request upon reboot or when force it to DHCP release and request this has no impact on the M7.
I grabbed some packet captures on the eth interface between my router and the M7 and even though the M7 is sending out ARP requests for who has <my router's IP passthrough DHCP assigned address from the M7> from the 192.168.1.1 address it has, the M7 is simply not responding to my router's ARP requests for who has <M7 gateway IPv4 address>.
I've double checked my own firewall and given that I can't configure my router for layer 2 filtering I can't have a rule that is blocking the ARP requests, so it has to be something with the M7.
- rcpaxJan 20, 2026Luminary
so going back to your original problem, like i said, my M6 Pro has no issue with connectivity even if I reboot the router that is connected behind it. My device is also in IP Passthrough mode. Maybe you do a factory reset and configure it again. that usually fixes most issues. if it still behaves that way, maybe your device needs a FW update.
[Don't worry, not expecting you to solve this, just adding info here...]
Ironically, the situation has worsened in the last few hours and now it won't even give out an IPv4 address after rebooting the M7... either in IP-PT or NAT mode :/
I've factory reset it multiple times and no dice.
All of this starting happening after an update a week or so ago... Current version: MR7400-1A1NAS_04.17.
