Slimshady25760
Oct 05, 2015Follower
MAC OS El Capitan issues with AT&T Aircard 340U
Good Afternoon, I use my MAC for business and this morning after upgrading to the MAC OS El Capitan latest release I am no longer able to use my Aircard 340U. It just keeps restarting the Aircard wit...
wolfscream
Oct 06, 2015Aspirant
I have the same problem
DarrenM
Oct 08, 2015Sr. NETGEAR Moderator
Hello Slimshady and wolfscream
You may want to try our newest drivers since you might have some older ones. Let me know if this works or not
http://www.downloads.netgear.com/files/aircard/AC340U/AirCard_Watcher_B4089.dmg
DarrenM
- jt95Nov 09, 2015Aspirant
Hi DarrenM -
I have the same problem as the original poster. I downloaded the recommended driver, but there is no change for me. The Airbeam device restarts constantly and the AT&T All Access application indicates, "Modem Unplugged". When I looked into the contents of the .pkg file, it seems it is from May, 2015, a good five months before El Capitan.
Is there a manual uninstall process for these drivers in order to "clean" out potential left over old drivers and install this updated driver? Is there another version to be released soon? This is pretty much garbage that a month after release, I cannot use a product which my company is paying a monthly service fee to a wireless provider.
For anyone else that stumbles upon this thread, is this firmware working for you on 10.11.x?
-jt
- noemailNov 19, 2015Aspirant
This driver has been tried to work with AC341U [Telus]
Unit was working before and stopped working after updating MacBook Pro to El Capitan
- noemailNov 21, 2015Aspirant
I have no idea why I decided to go in and try once again, but I did. I installed everything. Then, I updated my locations in system preferences to make sure all that information was correct.
I installed NETGEAR again, then I installed the link you sent today and it is working and I am sending you this email from my MAC.
It is important for people to note that they will have 3 locations while using this device:
AirCard 340IU
AirCard 341
Sierravsp
It is interesting all 3 are checked, so who knows which one is working, but it appears as long as you put in all your configuration information in all 3 places - it works!
Hope this note makes sense to you. I am grateful and thankful to be back on my MAC.
