Eagerbecky
Aug 10, 2016Aspirant
MBR1515 External Antennas
Help, I am moving to a remote area, my Verizon' phone works good there ,However my MBR1515 Mobile Broadband does not, can i connect a external antenna,s up to this unit , i see there are two antenna,...
DarrenM
Aug 12, 2016Sr. NETGEAR Moderator
Hello Eagerbecky
The antenna uses SMA connector. Netgear does not suggest using external antennas
DarrenM
Eagerbecky
Aug 18, 2016Aspirant
Thanks for information, I was able to locate a pair of outside antennas that work great, thank you for your information,
