K4r0lSz
Jul 27, 2026Aspirant
MH7150-100EUS (M7) – Has anyone successfully activated a carrier eSIM? (Plus Poland / Europe)
Hello everyone, I am trying to activate a Plus Poland (Plus na Kartę) eSIM on my NETGEAR Nighthawk M7 (MH7150-100EUS). Router information Model: MH7150-100EUS Software Version: 2.12 Purchased i...
K4r0lSz
Jul 28, 2026Aspirant
Update (after NETGEAR Support recommendations):
I would like to share an update in case it helps other MH7150 users.
Following NETGEAR Support recommendations, I performed:
- Full factory reset
- Fresh router configuration (no backup restored)
- New carrier-issued eSIM generated by Plus Poland
- Internet connectivity confirmed
- Latest available firmware (2.12)
- OTA reports no newer firmware available
The behaviour remains reproducible.
The router:
- successfully reads the QR code,
- contacts the SM-DP+ server,
- starts downloading the eSIM profile,
- reaches the final installation stage,
- then fails.
Originally the router reported Error Code 1.
After generating a completely new eSIM profile from the carrier and repeating the test after the factory reset, the router now reports Error Code 15.
Both eSIM QR codes use the same SM-DP+ server:
pkt.prod.ondemandconnectivity.com
NETGEAR Support has been informed and I have requested escalation to the firmware/eSIM engineering team.
If anyone has successfully activated a carrier-issued eSIM (not NETGEAR Marketplace eSIM) on the MH7150, I would really appreciate knowing:
- firmware version
- country
- mobile operator
- whether activation was done via QR code
Thank you.
Even a confirmation that a carrier-issued eSIM works on your MH7150 would be very valuable.
- K4r0lSzJul 29, 2026Aspirant
Update
I have some important new findings.
After further testing:
✅ Orange Flex eSIM installs and activates successfully on the same MH7150 (firmware 2.12).
✅ The Orange Flex eSIM remains fully functional after reboot.
✅ The same Plus Poland eSIM profile installs and works correctly on a Xiaomi smartphone.
❌ Plus Poland eSIM still fails only on the MH7150 with Error Code 15 during the final installation stage.
This suggests that:
the MH7150 eSIM functionality is operational,
the Plus eSIM profile itself is valid,
the issue appears to be specific to the interoperability between the MH7150 firmware and Plus Poland eSIM profiles.
NETGEAR Support has now escalated my case to the Level 2 team.
If anyone has successfully used a Plus Poland eSIM on the MH7150, I would really appreciate hearing about your experience.
- K4r0lSzAug 06, 2026Aspirant
Update – additional interoperability test results
After further troubleshooting, I have some new findings that may help identify the issue.
Test results
Device / eSIM / Result
MH7150 (FW 2.12) / Plus Poland / ❌ Fails during installation (Error 0 / 1 / 15)
MH7150 (FW 2.12) / Orange Flex / ✅ Successfully installs and works normally
Xiaomi smartphone / Same Plus Poland eSIM / ✅ Successfully installs and works
Additional observations:
Orange Flex eSIM remains operational after reboot.
Plus Poland eSIM consistently fails only on the MH7150.
After a fresh router reboot, the first installation attempt usually ends with Error Code 0.
Subsequent attempts without reboot return Error Code 1 or Error Code 15.
This behaviour is reproducible.
NETGEAR L2 Support has now requested an Instabug report, which has already been submitted together with a screen recording captured immediately after reproducing the issue.
At this point, the evidence suggests that this is not a general eSIM problem, but a possible interoperability issue between the MH7150 firmware and Plus Poland eSIM profiles.
Has anyone successfully activated a Plus Poland eSIM on the MH7150 (or any other carrier using the same provisioning platform -
SM-DP+ server: pkt.prod.ondemandconnectivity.com)?
- K4r0lSzAug 17, 2026Aspirant
Additional test result:
NETGEAR provided a goodwill eSIM (3 GB test profile).
The profile installed successfully on the MH7150 and data connectivity works correctly.
Interestingly, the profile connects through the Plus mobile network.
Therefore:
- Orange Flex eSIM → works
- NETGEAR eSIM → works (on Plus network)
- Plus-issued eSIM → fails
This further narrows the issue to the Plus-issued eSIM profile or its provisioning process rather than general eSIM functionality or Plus network connectivity.
- K4r0lSzSep 09, 2026Aspirant
Update – new Plus eSIM tested on firmware 02.24
Another test has now been completed using a newly issued Plus Poland eSIM profile on the MH7150 running the new firmware 02.24.
Unfortunately, the problem is still reproducible.
The test was performed after restarting both the MH7150 and the phone. The activation failed again, and I submitted a new Instabug report immediately after reproducing the issue, including a short screen recording of the complete activation attempt.
