K4r0lSz
Jul 27, 2026Aspirant
MH7150-100EUS (M7) – Has anyone successfully activated a carrier eSIM? (Plus Poland / Europe)
Hello everyone, I am trying to activate a Plus Poland (Plus na Kartę) eSIM on my NETGEAR Nighthawk M7 (MH7150-100EUS). Router information Model: MH7150-100EUS Software Version: 2.12 Purchased i...
K4r0lSz
Jul 29, 2026Aspirant
Update
I have some important new findings.
After further testing:
✅ Orange Flex eSIM installs and activates successfully on the same MH7150 (firmware 2.12).
✅ The Orange Flex eSIM remains fully functional after reboot.
✅ The same Plus Poland eSIM profile installs and works correctly on a Xiaomi smartphone.
❌ Plus Poland eSIM still fails only on the MH7150 with Error Code 15 during the final installation stage.
This suggests that:
the MH7150 eSIM functionality is operational,
the Plus eSIM profile itself is valid,
the issue appears to be specific to the interoperability between the MH7150 firmware and Plus Poland eSIM profiles.
NETGEAR Support has now escalated my case to the Level 2 team.
If anyone has successfully used a Plus Poland eSIM on the MH7150, I would really appreciate hearing about your experience.
K4r0lSz
Aug 06, 2026Aspirant
Update – additional interoperability test results
After further troubleshooting, I have some new findings that may help identify the issue.
Test results
Device / eSIM / Result
MH7150 (FW 2.12) / Plus Poland / ❌ Fails during installation (Error 0 / 1 / 15)
MH7150 (FW 2.12) / Orange Flex / ✅ Successfully installs and works normally
Xiaomi smartphone / Same Plus Poland eSIM / ✅ Successfully installs and works
Additional observations:
Orange Flex eSIM remains operational after reboot.
Plus Poland eSIM consistently fails only on the MH7150.
After a fresh router reboot, the first installation attempt usually ends with Error Code 0.
Subsequent attempts without reboot return Error Code 1 or Error Code 15.
This behaviour is reproducible.
NETGEAR L2 Support has now requested an Instabug report, which has already been submitted together with a screen recording captured immediately after reproducing the issue.
At this point, the evidence suggests that this is not a general eSIM problem, but a possible interoperability issue between the MH7150 firmware and Plus Poland eSIM profiles.
Has anyone successfully activated a Plus Poland eSIM on the MH7150 (or any other carrier using the same provisioning platform -
SM-DP+ server: pkt.prod.ondemandconnectivity.com)?
