K4r0lSz
Jul 27, 2026Aspirant
MH7150-100EUS (M7) – Has anyone successfully activated a carrier eSIM? (Plus Poland / Europe)
Hello everyone, I am trying to activate a Plus Poland (Plus na Kartę) eSIM on my NETGEAR Nighthawk M7 (MH7150-100EUS). Router information Model: MH7150-100EUS Software Version: 2.12 Purchased i...
Zellinor
Aug 04, 2026Initiate
I have a similar issue in France with Lebara.fr. It is impossible to activate the card because Lebara sends an SMS after the card is initialized to complete the process, but the message is never received on the M7's end (nothing shows in the web interface). Lebara is not very helpful in finding solutions either.
In the end, I used the Nomad eSIM (the Nomad app on iPhone), and it works well. But it is not as cheap as Lebara. I am also using firmware 2.12. Overall, I've found eSIM activation to be hit-or-miss, which is a shame because I bought the M7 for eSIM support.
K4r0lSz
Aug 06, 2026Aspirant
Thank you for sharing your experience.
Out of curiosity, do you know which SM-DP+ server your Lebara eSIM uses?
It can be decoded by AI from QR code, if it's not written directly, when carrier provide eSIM.
