K4r0lSz
Jul 27, 2026Aspirant
MH7150-100EUS (M7) – Has anyone successfully activated a carrier eSIM? (Plus Poland / Europe)
Hello everyone, I am trying to activate a Plus Poland (Plus na Kartę) eSIM on my NETGEAR Nighthawk M7 (MH7150-100EUS). Router information Model: MH7150-100EUS Software Version: 2.12 Purchased i...
K4r0lSz
Jul 29, 2026Aspirant
Update
I have some important new findings.
After further testing:
✅ Orange Flex eSIM installs and activates successfully on the same MH7150 (firmware 2.12).
✅ The Orange Flex eSIM remains fully functional after reboot.
✅ The same Plus Poland eSIM profile installs and works correctly on a Xiaomi smartphone.
❌ Plus Poland eSIM still fails only on the MH7150 with Error Code 15 during the final installation stage.
This suggests that:
the MH7150 eSIM functionality is operational,
the Plus eSIM profile itself is valid,
the issue appears to be specific to the interoperability between the MH7150 firmware and Plus Poland eSIM profiles.
NETGEAR Support has now escalated my case to the Level 2 team.
If anyone has successfully used a Plus Poland eSIM on the MH7150, I would really appreciate hearing about your experience.
K4r0lSz
Aug 17, 2026Aspirant
Additional test result:
NETGEAR provided a goodwill eSIM (3 GB test profile).
The profile installed successfully on the MH7150 and data connectivity works correctly.
Interestingly, the profile connects through the Plus mobile network.
Therefore:
- Orange Flex eSIM → works
- NETGEAR eSIM → works (on Plus network)
- Plus-issued eSIM → fails
This further narrows the issue to the Plus-issued eSIM profile or its provisioning process rather than general eSIM functionality or Plus network connectivity.
