Scotsman's avatar
Scotsman
Follower
May 27, 2016
MIMO window Antenna - Do I need to connect both connectors
Hi
I have recently pruchased a Netgear MIMO window Antenna fo ruse travelling with the kids.
Im conntecing it to a Hauwei E5776 mifi device but it only has 1 Ts9 connection port, will this make any difference or do I need a connector to connect both the Mimo Ts9 connectors into 1.
Thanks
Mark
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Scotsman
    It shouldn't make a difference but you may want to try if you are not getting good enough signal.
    DarrenM
