Chris0404
Mar 22, 2018Guide
Mobile hotspot LTE MR1100 won’t stay on when connected
This device will not stay on when connected to anything. It auto shuts off and the only way to get it back on is to remove and reinsert the battery. I have already swapped it out with another brand ne...
AoC
Apr 07, 2018Guide
That issue sounds similar with mine. I have random shutoffs, according the crashdump, caused by fatal error in SMS service of the device. I have sent error report to Netgear and I hope they will fix it to the next patch. I have MR-1100 EUS .
This is what is in crash report:
Src: FatalError
Dat: 0000011D
Str: sys_m_smsm_mpss.c
Fmt: APPS force stop
00000000 00000000 00000000 00000000
Task: AMSS0
Time: 000FE58D
R0: 00000000 R1: 00000000 R2: 00000000 R3: 00000000 R4: 00000000
R5: 00000000 R6: 00000000 R7: 00000000 R8: 00000000 R9: 00000000
R10: 00000000 R11: 00000000 R12: 00000000 R13: 00000000 R14: 00000000
PC: 00000000
CPSR: 00000000
Mod: Unknown
Ctr: ARM, IRQ en,FIQ en
TOS
00000000 00000000 00000000 00000000 00000000 00000000 00000000
BOS
App ver:NTG9X50C_12.02.07.00
Src: FatalError
Dat: 00000000
Str: Recursive fault!
Task:
Time: 00000000
PC: 00000000
CPSR: 00000000
Mod: Unknown
TOS
BOS
