Magicstuffin
Apr 12, 2021Follower
Mobile Wifi AC800S continually disconnects from the internet. PLEASE HELP!!
Please help!! I have an AirCard 800S supplied by optus. For the first month it worked fine. There is no nbn or ADSL available in my area and satellite service is just not good enough the speed is awfu...
ArodiD
May 19, 2021NETGEAR Expert
Hi Magicstuffin ,
What APN are you using with your Optus SIM? Can you try forcing the device to LTE All? On LCD:
- Tap Settings>Broadband>Band Region>LTE All
ArodiD
