xtv
Aug 05, 2016Aspirant
Monitor traffic on periodic billing (not monthly)
Hello, Recently my ISP (a major mobile operator in Europe) decided to change the billing period from "monthly" (on a fixed month day) to "every 4 weeks" (usually the period is shorter than a month s...
DarrenM
Aug 08, 2016Sr. NETGEAR Moderator
Hello xtv
I have no heard of any update planned to change this and I do not see a workaround seems checking your ISP data usage is the only way.
DarrenM
- xtvAug 09, 2016Aspirant
Hi Darren,
Thank you very much for the answer.
Is there an API on the AC available to access traffic information (e.g. in JSON format) and issue commands (e.g. to reset billing period)?
