WKC's avatar
WKC
MR 1100-100
Dear community, Please help! I try to install a new mobile simcard of Vodafone onto my MR1100-100 netgear M1. I enter the pin of the simcard, it works but when I switch the router or app off, and switch the netgear router on again, it has lost the password PIN of the simcard. Where can I make the router remember the password?? Or make it switch off the pin verification? I am desperate, because it needs to work for my job early mondaymorning. Thank you so much!
  • I found in the menu sim security that I need to fill in a Sim Pin to turn off/ deactivate the pin lock. They also ask for a 4 - 8 digit code to unlock your sim. What do they mean by the digit code? What is that? Where is it from and where can i find it?
    • Christian_R's avatar
      Christian_R
      NETGEAR Employee Retired
      Hello WKC,
      1. Do you still require assistance? When the router or app is turned off, you must enter a SIM PIN each time you power on the mobile router. This rule only applies if you have enabled SIM security.
      2. Before the device prompted for a 4 - 8 digit code, did you enter the incorrect PIN 3+ times? If so, the SIM is blocked and you would need to contact your service provider to unblock the SIM.
      ~Christian
  • Hi WKC,
    Sorry, help me understand.  I know you have a SIM from Vodaphone.  But what carrier is your MR1100 from ?  Is it the USA version (AT&T), the Austrialian version, European version, or the Kuwait version?
    Is the device locked to the carrier (aka AT&T) and you need to get an unlock code from the carrier first, in order to use your SIM from Vodaphone?
    -Jonathan
