Rossel79's avatar
Rossel79
MR 1100 Wifinetworks not showing
I have a MR1100 Wifi hotspot through firstnet.  My first hotspot stopped working and a replacement was sent by netgear last july.  In the last few months I have come to realize that my hotspot only works using an ethernet cable.  My wifi networks are enabled and set to display.  It says my firmware is updated.  I have done multiple factory resets and no one can seem to help.
  • plemans's avatar
    are you using it with it AC powered all the time?
    Do you have the battery removed?
    Is it set to performance mode?
    • Rossel79's avatar
      Rossel79
       no i am using it unplugged and plugged in.
      even with battery removed the wifinetowrks not showing
      Where do I change preformance mode?
      In all areas where the wifi should be turned on it is on and set how it should be to broadcast the wifinetworks and still none of them are displaying.
      I have tired to connect to the network by putting ssid in and it still does not connect.  The network names also don't show on the device screen.  When I try to connect by just entering the ssid name it still does not connect.
