VadiChek
Nov 24, 2025Tutor
MR 7450 is not detectable in mobile app..
Hello! Recently purchased an Nighthawk MR7450 mobile router and am experiencing the following issue: it can't detect in Netgear Mobile app. It's connected via Wi-Fi and web access is fine. I also hav...
samHoney
Dec 12, 2025Aspirant
I’ve seen similar behavior with some Netgear devices—sometimes the mobile app doesn’t detect certain models even though Wi-Fi and web access work fine. One thing that helps is making sure the router and phone are on the same network band (2.4 GHz vs 5 GHz) and checking that any mobile firewall or VPN is off. Other than that, it might be a device-specific app compatibility issue.
