vip991988
Jun 08, 2021Aspirant
MR1 1100 stuck when factory reset, can't connect wifi, ethernet.
MR1 1100 cannot connect to wifi for configuration.
Maybe i remove battery when MR1 1100 update firmware Y_Y .
Anyone help me to fix it ?
THANKS !! ALL
- vip991988Aspirant
it can't connect any devices, anyone can help me ?
- vip991988AspirantWho can help me to fix this ?
vip991988 wrote:
Who can help me to fix this ?We don't know enough about what you are doing and where it goes wrong. So it is hard to respond.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Factory Reset.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
