markuspookus's avatar
markuspookus
mr1100 - disable sip alg
Hi
Trying to use these devices as a failover for a cabled internet connection for multiple clients.
Got the failover working, however I need to find out if  SIP ALG is enabled by default and if so, how to disable it.
I cant see anything in the configuration
Currently testing the above M1, but the same question applies to the M2 ai I will be using these going forward
Mark
  • Hi Mark,
    SIP ALG is enabled by default on the MR1100.  There is no way of easily disabling via the webUI.  The latest Nighthawk M2 MR2100 however does give user the option to disable SIP ALG via the webUI.
    Arodi
    Community Team
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi Mark,
    Arodi
    Community Team
    • markuspookus's avatar
      markuspookus
      Thanks for that.
      So I ask the obvious question.
      Is there a Hard way to disable it, not using the WebGui ?
      Regards
      Mark
