UK-based
Feb 21, 2018Luminary
MR1100 + 2 access points - DHCP address problems
My Nighthawk MR1100 (M1) is connected via Ethernet to an unmanaged switch, into which 2 access points are connected to distribute dual band WiFi around the house. Since the most recent firmware updat...
UK-based
Mar 12, 2018Luminary
Has anyone else got this problem with devices not being allocated IP addresses by the MR1100's DHCP when moving between 2 access points that are wired to it via an Ethernet switch? Is this a problem with the MR1100?
