TM3522's avatar
TM3522
Tutor
Dec 20, 2019
MR1100-100EUS stop updates.
Hi,
like the subject..
I want a way to stop auto updates.
thanx
  • Hi TM3522
    Welcome to NETGEAR Community!
    There is no option to disable firmware updates on MR1100. You will be notified that there is an update available and will be given an opportunity to update the firmware 3 times. If after the 3rd time the firmware is not updated then MR1100 will update the firmware.
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi TM3522
    Blanca
    Community Team
