FixTheM1Please
Jan 17, 2023Aspirant
MR1100-100NAS Doesn't Automatically Re-Connect to Internet After Being In Bad Signal Area
Hi. I have struggled with this since last year. This M1 hotspot works great other than the main issue I have had: Re-connecting to it and the M1 re-acquiring Internet access after being in a really bad signal area without having to manually reboot it.
As you can see in the photo below, after the M1 hits very bad cell reception, it will eventually lose Internet access completely, making any devices connected to it say "connected without Internet." You can then go to a location that you know has good signal and it still will not re-connect to the Internet (cell connection) until you manually reboot it.
After waiting 10-15mins to see if it would auto-reconnect, it would not. Then, as expected and like I've done many times before, I get the successful result in the photo below the second I reboot the hotspot:
This has gone on for over a year, on two different M1 devices, on all the major carriers. It is a M1 issue. Please help or fix.
- JohnPengNETGEAR Expert
Could you please help to capture 2 model.json files:
1. Before rebooting the device after losing the network coverage and getting back to the coverage. The device should be in disconnected mode
2. After rebooting the device. The device should get back on the data connection.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backPlease send email to me at [email protected]
Thanks
- FixTheM1PleaseAspirant
Hi, any follow-up to this?
Hi there. Just sent the e-mail and attached the log files.
