phillm12's avatar
phillm12
MR1100 24/7/365 duty cycle for Nighthawk M1
This device tells me to remove the charge cable once the battery is 100% Can I ignore this and just leave the cable attached and powered up, I need to have remote access to this device 24 hours a da...
  • UK-based's avatar
    Jan 31, 2018
    Please see this post that covers the same question. There is also a link at the end of my post that explains how to run the M1 reliably without a battery and also deals with the possible use of a UPS to cover mains power failures. There's a lot of information if you follow the links and read all of the related posts.
    I hope this answers your question :smileywink:.
