JeromeF's avatar
JeromeF
Initiate
May 05, 2020
MR1100 and emoji in the SSID
Hello,
I want to add some emojis in the SSID of my MR1100 (european version latest firmware).
When I try to do that, it works but after the webUI is totally not responding. I need to do reset the router.
Is adding emojis is a supported feature or a bug of my firmware ?
Thanks
Jerome
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    This may be a feature request. Could you please advise what emoji you plan to use and cause the issue?
    Thanks
    • JeromeF's avatar
      JeromeF
      Initiate
      It was the fire 🔥 emoji.
      But I have tried with another like 😬 and I have the same issue.
      And how can I create a feature request ?
      Thanks
