PHIL032
Feb 09, 2021Follower
MR1100 Cannot connect using rj45 ethernet connection
I have no problem using the wifi for multiple devices but if I connect a machine using the rj45 connector I get nothing.
If I use the USB connection I get an IP address (still no internet)
If I use the rj45 ethernet connector I get no IP address (no internet)
I have tried every setting possible. Can the mobile device have computers connected via wifi AND a computer connected via ethernet? Is that even possible?
Thank you!
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi PHIL032,
Welcome to NETGEAR Community!Kindly access M1 Router UI and check the following settings:
Go to SETTINGS > Setup > Router Setup > USB port > select Charge Only > Apply
Go to SETTINGS > Setup > Router Setup > Ethernet Standby > set to Disabled > Apply
Here's a reference of how to access Router UI: https://kb.netgear.com/23379/
Blanca
Community Team
