motard's avatar
motard
MR1100 cannot update firmware
Hi.
I cannot update the firmware on my MR1100 router.
It has NTG9X50C_10.12.02.01 firmware now and on the app when I check for updates it comes up with a message saying update error and to try (I have hundreds of times). I found new firmware and downloaded it and tried to do it via a browser but there is no upload button. I'm having a few issues with the router and just wanted to start with updating the firmware.
  • Is it an unlocked ATT variant? If so without an ATT sim card you will not get updates
    • motard's avatar
      motard
      It's locked to Telstra (Australia) and the sim is Telstra.
      Other info I researched says to just keep trying and it will work but I have been doing that for a week now with no luck. And now the unit is shutting down.
