jeffgoodall
Jan 07, 2018Aspirant
MR1100 Chromecast setup
Having issues setting up chromecast with pc or app. initial setup goes well where i choose AP and enter security key, then chromecast reboots, comes up with picture, then times out and says reconnect...
JasonN
Jan 19, 2018NETGEAR Employee Retired
Hi Jeffgoodall,
I did some research and found this on our community KB. I do not see the MR1100 model on there.
https://kb.netgear.com/24510/Chromecast-NETGEAR-router-compatibility
- JasonN
- jeffgoodallJan 19, 2018Aspirant
I think it has to do with access point isolation on the wireless. hope they fix the issue soon.
- JasonNJan 23, 2018NETGEAR Employee Retired
Hi jeffgoodall,
The issue you are experiencing may be related to a known issue with Google Chomecast. You can search Google for "Google chromecast issue" for more information.
- Jason N
